The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Feed back from promotion request
0 Kudos
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
We are manufacturing industrial automation products. I am a team leader in PLM implementation.
2. What version of Windchill are you currently running?
12.0.2.0
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
We have created an activity task in project planning which can be started after approval of a document which is attached to a promotion request.
We are sending promotion request to next level for review and approval. We are not aware of  when they completed the review and approval.
Because of that, we need to keep on search and check the status of a document whether it is approved or still under review frequently.
If we can link the promotion request to the activity task (after completing promotion request, activity task should trigger like a predecessor relationship) or if we have a notification whenever the promotion request is completing a stage - review and approval, we can manually trigger the activity task.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
It saves user time.
5 Comments
MikeLockwood
22-Sapphire I
One approach to consider is this (not really elegant but may be a step better).
Create a group and add / remove interested users.
Make sure that promotion requests are created in a certain folder in each Product.
Subscribe the group to Promotion Requests, to the event of state change.
This will notify all users currently in the group when the Promotion Request is approved.
Note: Could subscribe the group instead to the Document object, for the event of state change.
Another way is to create a query builder report, save it, then create a data monitor.  Would need to work a little bit on the criteria that triggers this to avoid redundant notifications.  Again for this, the distribution ideally would be a group, but such reports can only be sent to individual user(s).
Sathish_Rosario
11-Garnet
@MikeLockwood
Thank you for your reply.
First one is good. But notification will send to mail id.
olivierlp
Community Manager
Thank you @Sathish_Rosario for your idea. Based on the information you provided, we are acknowledging it as the Community management team. This is not a commitment from the Product team. Other users may comment and vote your idea up.
From the subsequent conversation with @MikeLockwood, it seems that there may be an alternate way to achieve what you have in mind, although not exactly...
Sathish_Rosario
11-Garnet
@olivierlp
We are expecting predecessor relationship between promotion request and activity task.
olivierlp
Community Manager
Status changed to: Archived
