Windchill 10.2 M030. This is something difference in Workspace Create and Checkin functionality.
When user try to Check In objects from Windchill workspace, Check In process has an option for users to choose target context with the help of Set Location window.
Set Location window shows list of contexts to choose based on user read access. Actually the list of contexts should be filtered based on user write access i.e create permission. Currently this OOTB functionality creates challenges for users to navigate 100 of contexts in drop down to choose the right context. Also the effort gets multiplied when users need to work on multiple objects and then try to check in different objects into different contexts. There is an improvement needed here.
The similar filter functionality already exists in Workspace. Workspace's Create Part or Create CAD Document able to filter the contexts based on users write access and Workspace Check In not able to filter the contexts based on users write access.
We are looking for enhancement in Windchill 10.2 M030.
Requesting other customers who are in the same situation to vote for it
Ayyappan
