Hello, when there was the Creo View Plugin (Windchill 10.2) using ie_browser embedded in Creo Parametric or Windchill Workgroup Manager, open in Creo View action opened Creo View inside the embedded browser. The action "Windchill EPMDocument details" (right click on the model tree of CreoView) opened a Window inside the embedded browser, then were available the commands of the embedded browser, like "Open in Creo", "Open in Creo elements / Direct Modeling", etc...
In the past, when I upgraded to Windchill 11.1, I opened a case, 15008539 and I solved the issue with the option:
wvs.openincreoview.use.plugin.ie=true
Pratically re-setting the use of the plugin for IE.
But now I upgraded to 12.0.2.2 and the default browser is chromium, IE is no more supported by Microsoft and the property has no effect.
Now "Windchill EPMDocument Details" opens a new browser page, Chrome if installed, or error + Default Browser (Edge in out case) if chrome is not installed (Article CS335486 not solved in 12.0.2.2).
I would like a solution to raise the regression of new versions about this use case.
Nicola
