When using the chromium embedded browser with WWGM 11.1 and DPI scaling there can be extreme graphical corruptions causing the program to be unusable. This issue also affects Creo Parametric 4.0 as described in this post: https://community.ptc.com/t5/System-Administration/Creo-Parametric-4-0-embedded-chromium-browser-dis...
Some DPI settings appear to work without corruption, as well as when DPI scaling is disabled. However DPI scaling is required for many users based on their display resolution and vision requirements.
Please fix the chromium embedded browser so it works with any DPI setting.
