Fixed window size in export wizard in Windchill quality solutions
0 Kudos
If you closely look at the Export Wizard window in PTC Windchill Quality Solutions (desktop client), there are two columns 1. Fields available: 2. Fields to export:
Now, the problem is that this window cannot be resized and due to this lengthy field names for example 'Level 1 Supplier Resolution' cannot be seen completely. Part of the text is hidden due to the fixed visibility. It becomes very difficult, pain, and leaves us with the only to guess what the field could be.
Please see the snapshot below for better understanding
What is requested here from PTC?
  1. The Export Wizard window should be resizable so that field names of any length can be seen.
  2. Similar issue is seen with the 'Format Builder' window in desktop client. The window size should be resizable.
Thanks in advance.
Mohammed
1 Comment
olivierlp
Community Manager
Status changed to: Archived
