For an object, Subscribe > Edit Attributes Event, is it possible to know which attribute is modified
I create this idea after reading this article on TS.
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS185887&lang=en
4 Comments
BillRyan
Aquamarine
Marco, this is a good idea.  As a possible work around you could make it a best practice for the user to add a comment to the check-in field.  These comments show up in the subscription message for check-in...assuming every edit attribute event results also in a check-in event.
Marco_Tosin
Tanzanite
Bill, thanks for your suggestion.
I have already teach my users to use comment field but, as you know, not all user act in this way even if you teach them.
aadal
Newbie
It would be beneficial to see comparison result of previous version attribute values on Revise,  Check in and Edit Attributes events on subscription notifications. Thanks for the idea.
PTCModerator
Community Manager
Status changed to: Archived
