The PTC Community email address has changed to community-mailer@ptc.com. Learn more.
Geometry Compare in Part Comparison Window
Current Behavior:
Starting with Creo view 5.1, we have an option to Compare 2 Structures in one Single Creo View session.
This helps the user to open 2 versions of same structure to see parts / asm that are changed, added, removed, moved.
User can now use Part Compare action to get the comparison from Attribute and Structure
But when user wants to compare Geometry, it is not possible to do it in same Part Compare Window
Expected Functionality:
Can the above capabilities be extended in Part Compare action?
With this, user will get attribute, Structure and Geometry comparison in same Window
1 Comment
olivierlp
Community Manager
Status changed to: Archived
