The CS article states that you can change the folder location for things like promotion requests, change requests, change notices, parts, etc.
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS21487
I have modified my OIR for Promotion Requests to use folder.id of /Default/Promotion Requests/2016. This works fine.
I have done the same for Change Requests, /Default/Change/Change Requests/2016. This also works.
When I set Change Notice to use /Default/Change/Change Notice/2016, change notices fail to be created and I get an error. As soon as I reload the OIR with only /Default for the folder, I can create a change notice.
Shouldn't the folder.id setting work the same across all types of data?
Windchill 10.0 M040
I have not tested this in Windchill 11.0 m010.
When I did open a call with PTC support, their answer was works to spec. All of the Change processes should function the same or the spec for Change Notice is bad!
