Hide Security Label step in Create wizards after commenting object types in exposedSecurityLabelObjects.xml file
Security Label functionality is not hidden after commenting object types in exposedSecurityLabelObjects.xml file
How to hide Security label on specific Soft Type ?
https://support.ptc.com/appserver/cs/view/solution.jsp?n=CS118558
  • ExposedSecurityLabelObjects.xml file was only intended to control whether the Security Labels tab appears in the Manage Security UI
  • It was not intended to control whether the Security Labels step appears in Create wizards
  • There is no way to completely hide Security Labels for a specific SecurityLabeled object
2 Comments
SteveShaw
Status changed to: Under Consideration
This idea is understood and something we have captured in our backlog for future consideration.  Although it is not ideal, as a workaround, it may be possible to customize these create wizards to remove/disable the set security label step in these wizards.
olivierlp
Community Manager
Status changed to: Archived
