Homogeneous CAD-Templates
PDMLink provides the possiblity to create Creo Templates in the organisation. Unfortunatly it does'nt provide any possiblities to set Creo to pull these templates.
  • If I create a Creo Document thru the Workspace the user can choose which template he wants to use. These templates are organized in the organisation. (It's also possible to organize them in a product or library, but all these templates are being copied for each context. If a change occures, all templates of all context must be changed)
  • If I create a new document in Creo, the templates are mostly local or checked in to a library. There I have the possibility to set some config.pro variables
    • template_solidpart
    • template_drawing
    • etc.
If I have the templates in the organization I'm not able to set variable like start_model_dir.
The drawing frames have to be checked in to a library.
PTC changed the way new CAD documents are created for all 3rd party CAD systems. They put the new CAD-Document command into the Windchill ribbons. So new CAD-Documents can be created in the CAD-System with the PDMLink Wizard.
The best solution for Creo would be, if all templates (including frames, sheet stamps, etc.) can be saved in the organisation and a user gets the Windchill wizard also from File->New.
So please add the possiblity to switch the File->New Dialog in Creo to use the Windchill Wizard. With this possiblity the users also have to fillout the required attributes. It would help to organize all the different templates to one system.
And please add multilanguage supprt to the wtpub pathes:
German: wtpub://pdmlink/Bibliotheken/Templates/CAD-Documents/Frames
English: wtpub://pdmlink/Libraries/Templates/CAD-Documents/Frames
If a user switch the language, not all pathes must be updated in the config.pro.
Björn Rüegg
12 Comments
GregoryPERASSO
Aquamarine
definitely yes !
And stop semantic discussion about number, name, model name, common name , etc .... !
bmr
Peridot
Peridot
Are there any improvements in Creo 3?
SteveVinyard
Newbie
Asbolutely need this.  One of the biggest challenges is how to handle the creation of specific CAD sub-types or attributes (part family) that traditionally drive the name and number field.  If you use File>New, which is a must for many people, you get the old school "new cad document window".  You can't build any intelligence in, or set requred fields, or select specific soft types etc etc etc.  These features are absolutely required in advanced and semi-advanced environments.  We very much so need the option to launch a robust, windchill controlled, "New CAD Document Wizard" when you select "File>New" directly in Creo.  I'd even be somewhat happy just being able to disable the "File>New" option as then I could at least force users to use the menu in Windchill.
Mat
Marble
Marble
100% YES
Quite annoying bug, but PTC says it is a feature.
ailli
Guest
Absolutely important. In Replicated environements (Italy, Brasil...) it is not possible to control the Browsers language, so you have to define multiple config-pro's for each site, without a guarantee that this will work.
Mat
Marble
Marble
I did a work around for this PTC - "feature" by forcing the user's language settings to "English".
During Creo's startup a *.reg is loaded to local machine's registry:
Windows Registry Editor Version 5.00
[HKEY_CURRENT_USER\Software\Microsoft\Internet Explorer\International]
"CNum_CpCache"=dword:00000001
"CpCache"=hex:e9,fd,00,00
"AcceptLanguage"="en-GB,de-DE;q=0.5"
bmr
Peridot
Peridot
‌this idea is still open for voting, so it looks like PTC will provide the "New CAD Document" dialog in Creo 4 but doesn't implement all the other requested features...
PTCModerator
Emeritus
Status changed to: New Idea
Joerg-OlafSprut
Visitor
It should be definitely solved, because from time to time this issues occurs again and frustrate the users.
PTCModerator
Emeritus
JoshuaHouser
Pearl
Anybody have updates on this functionality?
victorazael_lop
Amethyst
Here to support the idea, as we would benefit on implement this.
