Our shop-floor workers use the Hotlink functionality as an shortcut to the drawings they need. So far so good. The problem is that the Hotlink points exactly to the object-version it was created with. When there is a newer version of the drawing, the Hotlink is connected with the older one and does not point to the latest version. Of course the details page gives the info that there is a newer version availabe but it can be overlooked easily. It would be great to have the chance to choise if the Hotlink should point always to the latest version or to the version it was created with. An other great thing would be if there is a possibility to export and import Hotlinks or to create a group/selection of Hotlinks for a group of workers.
