I want to access the Windchill by specifying a particular Method Server.
There is a problem, such as performance deterioration occurs in some Method Server.
In that case, we need to access the Windchill in Method Server occurring problem to confirm reproducibility.
However, because currently there is no way to access the Windchill by specifying the Method Server, it takes time to access an issue of Method Server.
Therefore, I want to improve so that it can access the Windchill by specifying a particular Method Server.
2 Comments
craymond
11-Garnet
In addition to having the capability to force which Method Server you are using, it would be nice to have a way to easily determine which Method Server a particular user is on.  There are often instances of issues on one MS, but it's hard to debug if you can't easily determine which one is having issues or test that MS yourself.
olivierlp
Community Manager
Status changed to: Archived
