If the priority of an workflow changes while the process is running, the following Work Items / Workflow Tasks were not updated but should.
If the priority of an workflow changes while the process is running, the following Work Items / Workflow Tasks were not updated but should. OOTB the priority stays like it was set at the creation of an change object / workflow. This it not nice. A priority can change e.g. when the reviewer or auditor decides that it should get an higher or lower priority...
The Windchill Help Center says that this is OOTB not intended, see https://support.ptc.com/cs/help/windchill_hc/wc102_hc/index.jspx?id=AssignmentsTaskPageAbout&action=show
--> Tab --> Details --> "Priority—Relative importance assigned to this process, entered when the workflow process started."
See also related discussions / product ideas where this would be helpful:
4 Comments
dritter-3
@PTCModerator :
Why has this product idea no "Status" ?
dritter-3
@JeffZemsky , the product idea has still no status. Can you please add it? Thank you very much.
AndrewK
Community Manager
Status changed to: New Idea
olivierlp
Community Manager
