Import from Spreadsheet' should support Similar Part Check OOTB Functionality.
Does PTC provides with any work around through 'Import from Spreadsheet' as the similar functionality works well through UI, when a user creates classified parts with attributes and those attributes are already used in previously create part in Windchill, then it pops up with a window "Similar part already exists. Do you still want to create a new part?".
2 Comments
Ismail_shaik
6-Contributor
Similar Part Check is not available on Part Edit wizard. It is available on Part Create wizard only. Not sure why PTC is not supporting it for the basic cases like  Part Edit and Part Import using a spreadsheet. Duplicate check is one of the important features everyone wants to have. Is there any configuration available to enable it for the cases mentioned above or at least any documentation around how to customize it?
olivierlp
Community Manager
Status changed to: Archived
