Import item IDs from Excel data into Clipboard or into a Managed Collection
It would be nice to have a function for import of item IDs from Excel sheet into Clipboard or managed collection.
For a mass change we need many different, not connected items, which are collected in one big excel sheet, sorted by item id. After import into clipboard (max size of clipboard 1000 itmes) i will use the data at release process, like copy and paste into affected and resulting objects list.
2 Comments
joe_morton
Yes, agreed!
There is no way to bulk select unrelated items. I would like a way to use the search tool where you could specify multiple strings in a single field, then you could copy what you wanted from the search results.
It could work using the | character:
XXX|YYY|ZZZ would return items with XXX OR YYY OR ZZZ
Interestingly, you can use this notation in a report, but not in the basic search function
olivierlp
Community Manager
Status changed to: Archived
