Trying to manage non-PTC CAD data (specifically Catia and Solidworks), and need to manage/store neutral file types (e.g. .stl, .pdf, and the like) derived from like data in Windchill, but can find no option for WGM to accept other file types. It can be (and is) done using the embedded browser in Creo using config.pro option allow_import_file_extension and list file types; been that way for years.... Earliest date of comments related to this task was 2013...
