It seems this portion of the workflow capability has gone unloved for some time. The UI is mostly unusuable without some customisation, the documentation to support the UI and capability is sparse at best. This could be improved by replacing the assignee text box with a Principal picker, ensuring that only valid task templates are available (pick a Promotion Template on a workflow that isn't a Promotion and see what happens), Improve documentation to describe what each field does and what is valid data, add a checkbox at the end of the list of tasks to simply state to return the task back once they adhoc activites are completed.
