Reliability Predictions using SN29500 as Failure Rate Models give inaccurate results for Temp <25degC since failure rates keep decreasing for T <25degC when the Siemens Standard SN29500 does not derate below this temp.
Product idea : temp field should be restricted to user entries > or equal to 25 degC only to avoid artificially low failure rates.
Regards
George Azzopardi
