Title
Improve NoClassDefFoundError error handling
Current
When NoClassDefFoundError error was appeared (on methodserver/bgmethodserver)
windchill cannot handle error.
NoClassDefFoundError was seen when workflow execution.
Improvement(Ideas)
If NoClassDefFoundError error will appeared, windchill should be improve so as to handle error and send mail to administrators.
(For example, out of memory case)
And administrators can be noticed some workflow was executed with error.
