Rehost utilies have bad performance while doing a rehost of an Oracle's base larger than 500 GB.
When using the parameters "ChangeHome", it can take a lot of time performing SQL Request, so we suggest that :
-Can we bind thoses request to have better performance?
-Is it possible to have "auto-commit" mode ? for exemple after 10000 requests.
-Is it possible to put "out of the box" the update of the table "ApplicationData" from the ChangeHome part of the rehost? (if we want to update this table after the rehost)
