Cascaded attribute value change on Edit page still shows the derived attribute with initially pre-selected value although the driver attribute is changed.
Whenever you change the driver attribute value, the list of the driven attribute should be updated according to the configured cascading attribute rules. This means the initially set value should be removed from the list for the driven attribute.
It doesn't make sense a user needs to manually set a driven attribute on the edit page while this driven attribute is set automatically on the creation page.
