Improve illustration creation from Process Plan in MPMlink
Hello everyone,
If I have a process plan with several operations which use same parts linked, if I create an illustration with Illustrate on each operation, it's impossible to retrieve as input for the illustration of the second operation the result (visualization) of the first one.
For example if this process plan is used to define the assembly process of a product (step by step), I have to redefine the previous actions (corresponding to the first step) on the second one, and made the same for each operation.
I think it should be very usefull to retrieve the result of each operation on the next. The visualization of each step already exist because it's possible to consult it.
BR
2 Comments
Francesco_Osti
6-Contributor
this could be very helpful!
same problem: I need to reuse the illustration of one operation in subsequent operation.
This will improve productivity and speed up the work.
olivierlp
Community Manager
Status changed to: Archived
