When the user viewing the structure of an assembly chooses to expand by an incremental number of levels the screen automatically refreshes to expand by that selection. If the user then chooses to expand by an increment less than the original chosen number of levels (example going from 3 levels down to 2 levels), the screen does not refresh. Even if the browser refresh button is chosen it does not properly refresh the table. Instead the user must first collapse all levels and then choose the new number of levels to expand by. This results in 2 picks instead of 1 every time a user wants to modify the amount of information displayed. Additionally, the collapse all menu pick does not appear if the right mouse button is used to pick the expand levels.
The improved functionality would be for the table to refresh every time, no matter what level of expansion is chosen.
