Improve the readability of base unit 'values' by providing an automatic unit selection feature.
Example: 100 pF Ceramic Capacitor
Reads: 0.0000000001 F
Provide automatic unit setting based on the value using multipliers/dividers in steps of 1,000. See below:
Capacitance: F, uF, nF, pF
Frequency: Hz, KHz, MHz, GHz
Inductance: H, mH, uH, nH
Resistance: Ohm, KOhm, MOhm
Voltage: V, mV, uV, KV
Current: A, mA, uA
Power: W, mW, uW, KW
