The current cascading attribute layout is great, but having to manually pick the items that are available in each layer is difficult when being used on larger sets of data. Instead of choosing the values, choose a sub-enumeration (with the already reduced list) to define the value list instead. That way only the enumerations and sub-enumerations have to be modified when new values or options are added instead of having to change the entire cascading tree.
