Any product can have several instances, each having its own serial number and configuration. In Windchill we can create a configuration, and then instance with serial number.
The idea is to add the ability to create the system file in WQS with the instance (wt.part.WTProductInstance2) or its configuration (wt.part.WTProductConfiguration) from Windchill
