Currently in the Generate LSAR file, the ALC code is input at the FMEA Table instead of the FMEA Tree Items/System Tree Items tab.
This make sense if the system file generated only has 1 LRU FMEA; however, if the system file generated has a BOM of mutliple Line Replaceable Units (LRUs), each LRU may have its own FMEA, which mean it may have its own separate ALC code.
One could handle this by generating different FMEA entries in the FMEA tab, however, generate LSAR file is only available in component FMECA, and only one component FMECA can be generated per system file.
The work around is when a FMEA is generated, the ALC will have to be switched out at the FMEA Table level per each LSAR file generated.
