This functionality is a must-have for end-users. The first time users come across this, they don't know that it is possible to change the context. Later, they are just stuck dragging the window. Functionality like this exists in other places throughout Windchill and just adds justification to the argument that Windchill is an antiquated application with a 90's GUI.
That's it. Should be a simple UI change to not auto-expand the list to be wider than the available area. Problem is still here in 11.1. I'd push technical support for an SPR on this one.
I will again connect with our internal team on this behavior, Although if we raise an SPR on this behavior, even that will be treated as an enhancement SPR.
