This Product Idea is posted on behalf of Customer PRODUKTIVNIE TEXNOLOGICHESKIE SISTEMY
1. In Windchill 10.2, if Default Representation of an Operation is created by PPE (Java Applet) ,we can find many attrbiutes of allocated WTPart in Creo View
2. In Windchill 11.0, we use PPB (Browser) to create Default Representation of an Operation, but with this way, only very few attributes about the allocated WTpart can be found in Creo View
We know this because some new designing in PPB (OperationHolderDynamicStructureGenerator java class) which generate pvs file in a different way, but Some customer may use the Attributes which only can be found in Windchill 10.2 PPE to create subsequent Illustration (Insert Attributes), so in Windchill 11.0, the difference will make customers cannot get same work instruction as Windchill 10.2
The suggestion is to add all that Attributes back in future Release
Sun Yi
