In Windchill's response, what can be resolved by setting in combination with Creo can not be set in other CAD
For example, if you attempt to modify a model that has not been checked out with CAD, Windchill issues a message urging you to check out the model
In this case, depending on the location to be modified, or the hierarchical structure of the model, the customer must respond to a very large number of messages
However, if this is a combination with Creo, it can be set to respond all at once
(dm_auto_conflict_resolution)
Because this setting can not be done, CAD users other than Creo will not be very productive
