Currently we have preference : "Structure" -> "Expansion Limit". It's used to provide a limit on Expand All Levels operations within structures.
When this limit is reached we have following message :
ATTENTION :The System defined expansion limit has been reached. Press 'Ok' to continue expanding the structure or Cancel to stop
It would be usefull to have a new preference, which allows to choose the behavior of the “Expansion limit” between :
- To continue or to stop (as currently implemented)
- Only to stop (not currently implemented)
