In "Article --CS238078", "The behavior is working to spec." But it is not correct.
0 Kudos
In "Article --CS238078", (title: Document link removed from an end item's latest version reappears in Collect Objects screen linked to the previous end item version in Windchill PDMLink.)
"The behavior is working to spec. The affected and resulting objects table only support the latest iteration of a revision. If a version is iterated after adding an object to either the affected or resulting objects table the new version will "Automatically reflect in the affected or resulting object tables.", But the behavior is different from the answer.
In the current behavior, the affected object table and the resulting object table will return all associated versions. (incorrect)
Only the latest version should be returned to the change apply object, as you only need to collect the objects to which the change applies. (correct)
3 Comments
olivierlp
Community Manager
Status changed to: Clarification Needed
olivierlp
Community Manager
Thank you for publishing your idea. However, we need more information as specified in the form you saw in the submission process. (questions below). The more details and context you give to document your idea, the better. Think about ways to educate and convince other Community members to support your idea and present your case to the product management team for consideration.
Please let us know within the next two weeks.
1. Describe your environment: What is your industry? What is your role in your organization? Describe your stakeholders.
2. What product & version are you currently running?
3. Describe the problem you are trying to solve. Please include detailed documentation such as screenshots, images or video.
4. What is the use case for your organization?
5. What business value would your suggestion represent for your organization?
Additionally, I invite you to check out this topic where 2 PTC executives explain product managers' approach to customer ideas and input for product roadmaps.
olivierlp
Community Manager
Status changed to: Archived
@YasushiIto  In light of your engagement in parallel with PTC Support, I am taking the liberty to archive your idea.
