Windchill does not support ACIS file (.SET) creation in Creo view adapters.
This option is now available in Autodesk Inventor Adapter , but not in the others, including CREO Parametric.
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS152784&lang=en
Would be interesting to get this option in the Publish Rule list (Like STEP, IGES, etc..)
