Indexing Creo Drawings with SolR
SolR is not able to index entirely Creo drawings (drw files) when the compression option COMPRESS_OUTPUT_FILES=YES is activated in the config.pro as described in SPR 2262752
With this option, the texts are compressed into binary data. SolR is not able to uncompress it.
Due to this issue the index search result is uncomplete (misses all the drawings having the same search text inside) and users cannot trust in results
An uncomplete search result is an unusable result!
SolR must include this "uncompress" ability
7 Comments
HelderNoura
STEVEG
Is there a way to see if a drawing had that set?  Is it saved inside the drawing somehow?
hager
6-Contributor
Hi Steve,
I believe the only way is to open the drw file in a text editor and try to find out if the file is compressed or not
For Creo of course, there is no difference: Creo opens compressed and not compressed file without any difference
Perhaps PTC can answer your question with more accuracy
STEVEG
I had already done that but all I looked for was "COMPRESS".
hager
6-Contributor
In the Text Editor, search for the text string which shoudl be indexed by SolR: if you can find it, it will be indexed. Otherwise, SolR will not be able to.
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
