Input data validation while filtering a search
After a search (for X8R ceramic capacitors -for example) when filtering out based on a parameter (Capacitance value - for example), the validation of the values (that Max. value has to be bigger than the Min. value) should be done only after pressing the Apply "button" / text, not before. This "early" check is very annoying and disturbing when several filtering out are performed.
The user has defined a valid search and filtered min and max value for the capacitance.
Then the user changes the min value so that it is bigger than the max value. As soon as he clicks in the field for the max value, he receives a message that the min value is not valid. Technically this is clear, because he did not change the max value yet.
But what is the Apply button good for, if the system immediately checks the input?
When Users are trying to enter invalid values in the maximum textbox for capacitance attribute, a new window pops-up saying, 'Invalid capacitance value' once clicked on apply. Post that once you click on ‘Ok’, the value entered in the maximum textbox disappears.
It should not happen, User should not be bothered to remember these values.
Please refer the screenshot.
1 Comment
AN_10069217
3-Visitor
PTC Case 16082450 is created for the above issue.
