Insert a new Component direct from a CS-Table
If I have a Assembly in Session, and I wish, to place a new Component from Windchill, i have to:
  • Assemble the Component via browsing in to the Commonspace or Workspace
  • Search the Component in Commonspace, add it to the Workspace and then place it via add New Component
So, I like to have the opportunity, to search the Component in Windchill, and then - direct from the CS- or Search-Result Table - assemble it in to the Assembly in session.
This could be done with a drag&Drop Action from the Windchill Browser in to the Session Window of Creo, and / or, with a new Action in the Result-Table, similar to "Open in Creo":
  • "Add to Creo",
  • "Assemble in Creo"
  • "Add to Session".
or whatever...
Thank you 4 voting this up!
Thomas
4 Comments
kdirth
20-Turquoise
Adding components not in workspace from Windchill can be accomplished by selecting assemble and typing the name.
I would like to see the ability to drag-and-drop from the workspace similar to what you can do from the working directory.
velico
7-Bedrock
see also a very similar idea:
Create "Assemble into active ASM"-Function
PTCModerator
Emeritus
olivierlp
Community Manager
Status changed to: Archived
