I read this article of TS and so I open this idea.
https://support.ptc.com/appserver/cs/view/case_solution.jsp?n=CS186366&lang=en
I think that PTC assumption is wrong.
What about if I create an attribute that inherited cost from ERP, and so can't be editable, but would like to use Structure tab to export data to estimate the cost of a new product?
