After running an Interference Detection Job the system creates a report in Windchill with all interferences found. This report in Windchill has many columns, which have important information to be able to investigate and manage the interferences. These columns should also be visible in Creo View interference list. Then the user has in Creo View not only the geometry of the interfering parts, but also the necessary attribute information in the columns.
In addition also customized attributes should be visible in Creo View list.
