Currently the Inventor PDF viewables are generated in color. However it would be good to have an option in the recipe file to indicate that all colors should be converted to black.
If white lines are now used in Inventor (with dark background) the white lines are no longer visible on the generated PDF (with white background).
This makes the current drawing PDF viewable unusable.
