Inventor integrate_Map a attribute from Autodesk Inventor to Windchill EPMMemberLink
Autodesk Inventor contains a paprameter "item" in "BOM managment". Designers can use this parameter conveniently to direct people to product. But when they use Windchill system, the bom can not be mapped to the correct attribute. The EPMMemberLink is not available.
3 Comments
Benjamin.Matt
1-Newbie
Well, I think your statement is not completly correct. The structure of the cad assembly is realized by epmmemberlinks. But you are right regarding that for CAD structures created with Inventor the usage-attributes are not stored on this link as it is possible with creo parametric.
So, we need the support to store usage attributes for Inventor in Windchill.
ngiacom
Hello. I voted your idea, I've the same problem with Creo Parametric. I've now created a new more general idea:
Add Support for Mapping of EPMMemberLink relationships between EPMDocuments
vote it!
PTCModerator
Emeritus
Status changed to: Archived
