When mapping a mcad attribute to an Instance Based Attribute (IBA), we have to establish a new attribute for the specific mcad software. But there is a limitation: blank space is prohibition. If it’s used, the attribute mapping must be failed.
So, is it possible to add a blank space between two words instead of an underline in New Attribute window?
