When using the WQS RBD module our user have seen a issue with calculating each individual block diagram. We have my Program that require large scale block diagrams. And to calculate each block individually is very time consuming. Having the capability to run the calculation for all diagramat once would be a great time saver. This capability willhelp our users work more effectively and efficiently. We are looking at a savings of approximately 40 hours with this capability.
