Is it possible to view the process plan structure in occurrence mode?
Use Case:
Consider user allocated 5 screws to one operation.
Later wants to move 2 out of 5 to another operation, it is not possible.
User has to remove the Allocation and then show occurrences in the tree picker and allocate the screws as desired. If Process Plan can show occurrences, then user can move the screws from one operation to another
