It should be possible to generate "Mission Reliability Results" report for FIDES
0 Kudos
When we generate a "Mission Reliability Results" report with a FIDES project it doesn't work and display a message saying that it is empty.
It seems that the problem cmes from the fact that the mission calculation is not performed for FIDES when the calculation is launched.
Step to Reproduce:
We work with a FIDES project with a FIDES Mission Profile with several Phases.
When we launch the calculation, the Mission Calculations checkbox is grayed. So any mission profile can be selected.
We launch a report (Tools/Report Wizards):
- Table Type: Mission Reliability Results
- Selected fields: Phase, Reliability, Failure rate, MTBF
- Data grouping: Phase
The report generation is launched. But once generated, the report displays a pop up with the message: "The report 'Mission Reliability Results' cannot print because it is empty"
With MIL projects the report can be generated. Note that the calculation wizard allows to check the Mission Calculations checkbox and choose Mission Profile (defined in Suport Files/Setup/Mission Profile) for MIL.
The case 15966841 confirms that to get a proper Mission Profile report for FIDES it must be possible to launch Mission calculation for FIDES, using FIDES Mission Profile (Support Files/FIDES Mission Profile). This feature is needed.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
