License Exclusion Group - Change License Counting Behavior
Please modify the license exclusion group behavior to allow users with mutually exclusive license profiles to be present in the license exclusion group simultaneously.
The current approach requires users to be added to the license exclusion group first, and then the exclusion group added to the license profile(s) and/or group(s) second:
This approach means that all license exclusion users will have the same permissions.  It's not currently possible to have basic test users, power test users, and administrative users all present in the license exclusion group simultaneously, each with their own separate licenses and permissions.
Please modify the license exclusion group behavior so users can be added to both the license exclusion group and other license groups simultaneously and independently:
This new approach would allow different types of test users to be created with different permissions levels.  This is especially important when granting the administrators wgm permissions for publishing purposes but not wanting to grant all license exclusion test users those same administrative permissions.  (See CS291518
Forcing all license exclusion members to be assigned to the same licenses and groups doesn't permit proper configuration and testing.
Please re-open SPR 8232457 and add support for use case #1 above (CS304558).  Thanks.
