Need the ability to Revise an object from Numeric to Alpha based on the Target End State identified within a Change.
Boston Scientific uses Numeric Revisions for Concept, Concept Build, PreReleased and PreProduction end states. We use Alpha Revisions for Released and Production end states. Upon going through the review process, the approvers need to see the correct revision level on the objects for approval. These objects will all be at a Review state to lock editing during the review. The Revision level will need to be correct based on the Target End State.
