This limitation is caused due to the installation of patch 25 which enabled the ability to add colorway chip attribute to the thumbnail view . We are not able to print more than 6 or 7 attributes onto the PDF containing images. Customer would like to have the ability to print 12-15 attributes along with the images in the PDF generated ( printing 12-15 attributes was possible before the installation of Patch 25).
Windchill Version : 10.1 M010
