The usecase is that you need to specify different attributes or number-serie based on the CAD doc type (CAD Part, CAD Assembly or Drawing). When creating a drawing the drawing shall pick the right epm-subtype. A common use-case is also that customers have different numbering schemes for different drawing types (welding drawing, detail drawing etc). I konw that this is not best practice, but it´s a reality.
There you can enable some different types for each doctype. I uploaded you the XML File. Place this into the codebase, create the subtypes and ready to go (Unfortunately I can't attach a file to this idea so I will paste the content directly to the message...)
