LoadFolder with description
Add property Description When create SubFolder by
In csvmapfile.txt edit
SubFolder~create~wt.folder.LoadFolder.createSubFolder~user~folderPath~description~adminDomain
In standardX24.dtd edit
<!ELEMENT csvSubFolder ( csvuser, csvfolderPath, csvdescription, csvadminDomain )>
Edit class wt.folder.LoadFolder
public class LoadFolder {
     public static boolean createSubFolder(Hashtable paramHashtable1, Hashtable paramHashtable2, Vector paramVector){
          // After create localSubFolder update property "description"
          String strDscr = LoadServerHelper.getValue("description", paramHashtable1, paramHashtable2, 1);
          if (strDscr != null && !strDscr.isEmpty()){
               Transaction localTransaction = new Transaction();
               localTransaction.start();
               localSubFolder.setDescription(strDscr);
               PersistenceServerHelper.manager.update(localSubFolder, true);
               localTransaction.commit();
               localTransaction = null;
Exampel CSV
#SubFolder,user,folderPath,description,adminDomain
SubFolder,,/Default/Test,Test Descript,
Exampl XML
<?xml version="1.0"?>
<!DOCTYPE NmLoader SYSTEM "standardX24.dtd">
<NmLoader>
  <csvSubFolder handler="wt.folder.LoadFolder.createSubFolder">
    <csvuser></csvuser>
    <csvfolderPath>/Default/Test</csvfolderPath>
    <csvdescription>Test Descript</csvdescription>
    <csvadminDomain></csvadminDomain>
  </csvSubFolder>
</NmLoader>
1 Comment
PTCModerator
Emeritus
Status changed to: Archived
