Loading and Viewing Creo Parametric files into Creo Elements Direct Modeling through WWGM.
Creo Parametric files (*.prt, *.asm and *.drw) cannot be seen while using the Windchill Workgroup Manager client for Creo Elements Direct even when they are in the same workspace as Creo Elements Direct Modeling files (*.sdp, sda, etc..).
In a multi-tool environment we need to be able to view the Creo Parametric files and also load these files into Creo Elements Direct Modeling all from within the Windchill Workgroup Manager client. This limitation within the application impacts downstream usage of the cad models and drawings.
1 Comment
olivierlp
Community Manager
Status changed to: Archived
